I was dialing in the carb on my '66 L36 this evening and was curious about the vacuum reading I was getting. The car is set-up with a stock list 3606 carb (a.i.r. 427 with the smog pump nutered and holes blocked). I was getting a vacuum reading off of the AC/PB tee of 15-16" at 600 rpm idle. Based on past posts, this seems a bit high to me.
I'm doing my best to dial her in, but I am thinking the advance is kicking in too soon because of a high vacuum. The advance can is stamped "355MS". The distributor was set-up by a reputable performance shop, and they said they mached the curve to the can. Seems to run pretty good after my rookie tweaks, but always looking for more HP if possible.
Suggestions on settings?
