I recently removed my spark plugs from my '66 327/350hp. I expected to find my plugs carbonized, wet, or oily but not soot covered - as I did. An associate of mine recommended that I change/check the valve stem oil seals. Does anyone think this my be a good course of corrective action. A bit of background - I had often needed to pump the pedal 4x-6x before ignition caught, tired of this I pulled all the plugs, noticed the condition, thoroughly cleaned and replaced and much to my delight within 1.5 - 2x pumps my hard (cold) starting was gone. I'd like not to have to pull the heads but can imagine that if the plugs were this sooty then the space around it couldn't have been much cleaner.
Suggestions/Comments welcomed.
As an aside, when I cleaned off all the grease and crud from my valve covers I discovered the "seam" through the 'o' of Corvette. My car's build date indicates ~ Nov. '65, doesn't seem to me that these valve covers are "correct."
