66 Center console rebuild - NCRS Discussion Boards
  • Ken Harants
    I am rebuilding my center console on my 1966 Vett. I purchased the aluminum replacement pieces, shift patten and the aluminum surrounding the gear shift. My question is do I remove the aluminum pieces that are on the console or apply the new pieces on the old?
  • Ken Harants
    Re: 66 Center console rebuild
    I forgot to add. If I replace how do I get the old pieces off?
    • Joe C.
      • August 31, 1999
      • 4598
      Ken:
      Remove the old, replace with the new. Use lacquer thinner to clean up the original adhesive. The new shift pattern can be discerned by experienced judges, as a replacement. Keep that in mind during your restoration.
      Joe
      • Richard Hayes
        Ken,
        Best way to remove the old aluminum is with a heatgun and a small putty knife.
        Check your replacements to the original ones- I have seen SEVERAL repops that aren't even close to originals-much less fit w/o work.
        Richard
        • Mike M.
          Director Region V
          • August 31, 1994
          • 1464
          On originals, the brushed texture of those 3...
          console pieces also matched that of your glove box door.
