The idle on 1964 327/300 is very rough due to an intermittent "miss" occurring every one to 5 seconds. I have frequently adjusted the idle mixture screws (used vacuum gauge to obtain highest amount of vacuum) but the problem persists. The engine runs fine at higher rpms. I cranked the idle speed up to about 800 rpms to prevent stalling. I can still feel the miss, but higher rpm prevents stalling.
I know the car is running a little rich because the idle speed increases when I disconnect a vacuum line. In fact, I am driving around now with heater control valve vacuum line disconnected. Other than adjusting the idle mixture screws, how do you correct an over rich situation? I have eliminated all the usual suspects (rebuilt carb, replaced plugs and wires, new points, condenser, coil, vacuum can, etc). Could a bad valve be the culprit?
Any suggestions would be greatly appreciated.
