Hi Everyone:
Getting ready to install my rear spindles into the trailing arms but before I do I have a few questions:
- Which direction is the parking brake anchor bolt retainer installed? I.E. Which end is up?
- I've greased my rear spindle bearings with a bearing packer, however is additional grease applied to the cavity in the spindle support between the inner and outer bearing races?
- Lastly, the lever which the rear parking brake cable attaches to has a loop. Is the loop installed facing up or down? As I have it installed the loop is up where you can see it and the parking brake cable lays on top of the lever after the cable is installed. I tried to install the lever with the loop facing down and I couldn't get it through the backing plate.
Any help would be greatly appreciated
Thanks Joe
Thanks Joe
