Ballast Resistor 1961 270HP
Re: Ballast Resistor 1961 270HP
There were two ballasts used in production. One measured about 0.3 ohm and the other about 1.8. Their appearance is identical. Service replacements, when they were available were differentiated by a "black dot" for the 0.3 ohm unit and a "blue stripe" for the 1.8. These marks were placed on the steel bracket with what appears to be a marker pen. Some say these marks were also on production resistors, but there is controverys over this.
As a general rule the high output engines used the low ohm unit for more spark energy, but the unfortunate by product was more frequent point burning. Your AIM should show resistor utilization for the base engine and various options.
"Generic" 1.8 ohm ballasts are commonly available, but their appearance including terminal design is not as original.
I don't know if the one you bought is detectable as non-original by it's appearance. If it is a "reproduction" that is meant to appear original, it is probably available in both resistance values, so you should contact Paragon.
The resistor alone may not be the cause of the burned points. To high a dwell angle (too little point gap) is also a common cause of burned points.
Duke- Top
Thanks! Duke
We had the engine running very well last evening and the same problem occurred this morning when I tried to start the engine. I have another question in reference to setting dual points.
We set the dwell on the points at 24 to 25 and when we took a combined reading we were in the range of 33. We set the points one set at a time with a piece of cardboard between the contacts of the points that we were not setting.
Do you have a better way of setting these points? I hope this is one of the last hurdles I have to fix. It is time to drive and enjoy the car.
I called Paragon and need to call the Tech Center; the sales person could not answer the question on Ohms.
You have been a great help on my restoration project!
Thanks, RayRay Carney
1961 Sateen Silver 270-HP
1961 Fawn Beige 315-HP- Top
Ray, you may want to check the circuit wiring from the ballast resistor to the ignition switch. It could be the "run" side of the ballast is hot all the time even when the ignition switch is in the off position. Thought the voltage across a properly functioning resistor is not detrimental to the points, a continuious current flow (engine not running) through points, when closed or just touching, will burn the points and damage the coil (it will get hot enough to blow the oil seal on the can). Maybe something to check?- Top
John is an expert on the dual point distributor. I have never owned/worked on one, but I recall from previous discussions that each set should be set to 29 degrees separately and the total should be about 34.
With no window and screw adjustment, setting the points on this kind of distributor is a PIA, but it sounds like your setting is reasonable and not too narrow.
Hopefully, some of the dual-point experts will chime in.
Duke- Top
