73-74 Air Cleaner - NCRS Discussion Boards
73-74 Air Cleaner
  • Roger S.
    • May 31, 2003
    • 262
    73-74 Air Cleaner
    Is there a difference between the dual snokel air cleaner for the 350 and the 454 engines? If so what is it.
    Roger
  • Terry Westrick
    Re: 73-74 Air Cleaner
    The air cleaners are the same. The ring on top is different (the ring that holds the gasket, air cleaner to hood seal). The BB is offset about an inch to the rear, where the 350 is centered.
    Hope this helps.
    • Dick W.
      • 10483
      Make sure which one you are purchasing. I am not sure now, but in the past the one for the small block was being passed off as also fitting the big block
      Dick Whittington
      • Harmon C.
        • August 31, 1994
        • 3228
        The 73-75 Air cleaner base has the position of the square breather hole in two locations. Be sure of what you need. They are often advertized to fit all but they don't. Lyle
        Lyle
        • Dick W.
          • 10483
          Keen Corvette has the small block adapter ring for the 350. I cannot find anyone that has the ring for the 454. See link
          http://keenparts.com
          Dick Whittington
