Hello Everyone. I hope your summer is going well.
I'm posting this question for a friend who just restored his 1969 convertable this year and may be logging on this site in the future.
His situation is: 454 BB from a 1973 in his 1969 is running 240 degrees hot. This has him quite concerned.
My thoughts are: Take an actual temperature reading at the point where the temp sending unit is mounted and compare with the gauge. (I believe there were multiple placement options for the sending unit. Which location is correct, I don't know.) Then calibrate the gauge if necessary by adding resistors.
Then, if the problem is confirmed, replace the thermostat with a maxi-flow 160 degree thermostat. (Does anyone know who sells them nowadays?)
What are your thoughts? I will print each response for his review.
Thank you.
Tony
Thank you.
Tony
