I have seen several examples of rear axle stampings with a numerical prefix (a "2" in several cases) immediately in front of the letter code which specifies the ratio, i.e. 2FB 9 10 68W. I have an original piece of 1968 GM literature which decodes axles for Corvettes and trucks and it indicates a two-character prefix for "Division" which may be found in front of the ratio letter codes. If this "2" is for Division, what Division is this? Thanks.
Rear Axle Code "Prefix"
Re: Rear Axle Code "Prefix"
Thanks John - I guess that means there are a few rare Corvettes running around with Pontiac rear ends! Does anyone know what the prefix signifies? As I said, the prefix is observed, and one example can be seen in Tripoli's Chassis book on page 55 (with no explanation about the 2). I believe the numbers which represent the shift are usually at or near the end of the assembly stamping - maybe they are the prefix occasionally?- Top
