well the car stalled out again on the road, so i went in and checked the elecrical connectors on the bulkhead and found them to be corroded quite a bit. some of the little prongs were totally green, i guess this is some sort of copper oxide.
this is undoubtedly the source of my problem. i was wondering if there is any liquid solution that can be used to clean this corrosion off? or would i be better off just scraping it off.
i will use some corrosion preventor before i plug it back together.
thanks
mike
thanks
mike
