Hi,
When I decelerate I get a knock. Specifically, if I rev (with/without load) up past 3800, the engine sounds fine, until I lift off the throttle, then I get a rattle/knock until I get below 3800. Then it's fine. The sound is localized in the front of the engine. Someone has suggested that this is a timing gear problem. I replaced the gear, chain and cover as well as the water pump. The cam had no noticable play, and the dist cam rotated immediately when I rotated the engine from the crank. I've been told that it's possible that the timing cover (aftermarket) is incorrect. I've also been told it's possible that the water pump, even though said to be correct, is slightly too small, compressing the timing cover and causing the lack of clearence that results in the chain hitting it on decel. That sounds crazy to me, but when you ask questions, you get all kinds of answers. Hey Joe L, ever heard of this?
Thanks for the help,
Ed
Ed
