C3 / Tire Lock Chamber - NCRS Discussion Boards
  • Mike Johannes
    Hello,
    Was hoping someone would walk me through how to remove the Tire Lock Chamber from the Tire Lock outer casing...would like to re-key. 1973 Corvette
    Thanks - mike
    41610
    (704) 575-6379
    Re: C3 / Tire Lock Chamber
    General proceedure is discussed in the lock section of your copy of the Chassis Service Manual.
    (1) Insert key into lock.
    (2) Take a paper clip or similar small diameter pushing device and insert into the lock's release hole (adjacent to the bezel).
    (3) Push the lock release with the paper clip and turn the key BACKWARDS and extract the key + lock cylinder from the lock body.
