I decided to tackle a clutch replacement in my '64 driver (original motor but C3 transmission). I've done a few in my life but never a Corvette. I have the transmission out but it was a challenge, even with the car on a lift. I eventually had to remove the linkage which made the job much easier. Now pulling the engine seems like the right thing to do for a cosmetic makeover of the engine and bay.
I've read in the archives the pros and cons of reinstalling the engine with the trans attached or not. Based on my experience while removing the trans, I will mate the units and install all at once. I hope to be able to rent an engine hoist with a leveler to tilt it into place. I have a couple of questions. I would really like to reinstall the linkage beforehand. It's a Hurst shifter if that makes a difference. Is that wise or will I have clearance issues?
Secondly, I will buy a new flywheel, pressure plate, clutch disc, throwout bearing, throwout bearing fork, and pilot bushing. I want to stick with all GM components. Is there a source on the net that people trust for good service and good prices or do I go to my local GM dealer?
The input shaft is 10 splines. I'm assuming I'm buying components that match the engine config (327-365hp), not the transmission. Correct? I have part numbers culled from various archive messages but if someone has them all handy I would be most appreciative.
I'm sure more questions will develop but this is a start. Thanks for any and all input. David
