I went to a grat event this weekend. VETTES ON THE ROCKIES about 500 plus Corvettes showen and shinen in the little town of Frisco next to Breckenridge. I was worried about hot starting and idle with my FI car. I posted questions about Reid vapor pressure and after some thought found a local racing fuel supplier that had 100 Octane gasoline that had a much higher set of boiling points than normal fuel 256 vs 198. It solved the hot start and idle stability problem. All you FI guys I think this is the answer.
Anyway, the thing I was worried about wasn't the problem. When I got up in the morning , it was about 40 degrees, I was worried about a cold atart. No problem, started and idled beutiful. The problem came when I put the brakes on as I was leaving the parking lot. No pedal !!!!!. I pumped it like crazy and it finnaly got enough pedal to stop the car. For the rest of the day the pedal was a little soft but worked fine. I got it home and it sat all night, as I went out to take it this morning the pedal was again very soft. I pumped it up and it stayed fine. I don't see any brake fluid leaking , although I haven't inspected in detail. The fluid level in the master cylinder is right up there. What the heck is going on! Is it general air in the system or a problem with the master cylinder. Any ideas or tests to narrow the problem down? Jerry
