C1 - Rear end howl... - NCRS Discussion Boards
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    Sounds like this "howl" is coming from the rear end. Is quiet on acceleration and straight and level, but goes nuts on decel. Any particular thoughts? TIA
  • Roy B.
    • February 1, 1975
    • 7044
    Re: C1 - Rear end howl...
    In the OLD days and I'm OLD we determined rear end noise by driving .
    1. howl on ether acceleration OR decel, meant PINION bearings.
    2. howl on turns left or right was AXLE bearings.
    3. howl all the time CARRIOR bearings.
    OR you may have lost pinion load on the pinion crush sleeve check to see if the pinion yoke nut came lose.
    And Dennis your OLD and should know that.
    • Tracy C.
      • July 31, 2003
      • 2739
      DC,
      Mikey's rear end howls too. I'm sure it's for a different reason though.
      tc
      • Dennis C.
        • January 1, 1984
        • 2409
        tc, Knew I'd recognize Mikie's smile... dc *NM*
        • Joe C.
          • August 31, 1999
          • 4598
          Dennis:
          That usually means improper ring and pinion alignment.
          • Chris S.
            • January 1, 2000
            • 1064
            the backlash between the ring and pinion gear is not set correctly.
            1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
            Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
            1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
            1957 Corvette - FI 3 sp - Black and Silver
            • Dick W.
              • 10483
              MM has a very unique smile *NM*
              Dick Whittington
              • Mike M.
                • May 31, 1974
                • 8365
                Re: tc, Knew I'd recognize Mikie's smile... dc
                my barrister will be in contact with you and tc for defamation of buttocks. mikie
                • Dennis C.
                  • January 1, 1984
                  • 2409
                  Thanks Guys & Mikie's louvers are special... *NM*
                  • Tracy C.
                    • July 31, 2003
                    • 2739
                    well it's about time you show up again..
                    I was beginning to think you got lost in Canada. Haven't heard or seen much from you on this board since you posted warning that the "farm use" 61 was loaded up and you were heading out.
                    Now that the word is out on you in this git'up, I'm sure they will be look'in for a repeat performance at Carisle this year.
                    Don't let us down...
                    tc
                    • Tracy C.
                      • July 31, 2003
                      • 2739
                      "special" may have multiple meanings here ! *NM*
                      • Dick W.
                        • 10483
                        You and Loren kissed and made up???
                        Dick Whittington
                        • Mike M.
                          • May 31, 1974
                          • 8365
                          Re: well it's about time you show up again..
                          i'm already at the Carlisle Fairground, waiting to assist the first vendor's arrival to help him/her unload their goodies. strictly humanitarian gesture on my part. am traveling in cognito, however. look for skirts this year. mike
                          • Tracy C.
                            • July 31, 2003
                            • 2739
                            you sneaky weasel .."humanitarian gesture" my butt *NM*
