C1 GRILL FINISH - NCRS Discussion Boards
C1 GRILL FINISH
  • Joe D.
    • April 30, 2002
    • 382
    C1 GRILL FINISH
    What is the correct finish for a 1961 grill. Thanks for the help. Joe DeLuca #37862
  • John S.
    • September 30, 1997
    • 263
    Re: C1 GRILL FINISH
    1961 grille is silver.
    • Joe D.
      • April 30, 2002
      • 382
      Re: C1 GRILL FINISH
      Is it a silver anodize? Thanks, Joe
      • Wayne P.
        • August 31, 1975
        • 1025
        YES! *NM*
        • Dennis C.
          NCRS Past Judging Chairman
          • January 1, 1984
          • 2409
          And, I think I just learned...
          there is a rather "thick" original configuration and a later service replacement or reproduction, quite "thinner" offering. I just know enough to be dangerous here, but thought I'd pass it on... Best, Dennis
          • Mike M.
            • May 31, 1974
            • 8365
            Re: And, I think I just learned...
            where'd ya learn this? you're correct, the orig 61's are about 30% thicker than the NORS grills that gm serviced in the 70's. mike
            • Tracy C.
              • July 31, 2003
              • 2739
              Assume you are talk'in about the metal gauge thickness. Might help if someone can slap a Mike (micrometer that is) on an original farm use 61 to determine a baseline thickness from which to compare.
