Any suggestions about where to find an ECM for a 1982 Corvette? The Vette has a 350 automatic. Any help would be greatly appreciated.
82 ECM
Re: 82 ECM
Isaly-----
If it's an 82, I hope that it's got a 350 with automatic; that's the only way that ANY 1982 Corvette was ever originally built.
Anyway, the part you need, GM #1225550, is GM-discontinued. However, it may still be available through Delco dealers under that number. Otherwise, try BBB Automotive at www.a-1injectors.com. They can sell you a re-manufactured example of the GM #1225550 (the GM part was a remanufactured piece, too).In Appreciation of John Hinckley- Top
Re: 82 ECM
I believe the '82 Camaro/firebird crossfire engine ECM will work as long as you use the Corvette cal PROM.Bill Clupper #618- Top
