C-2 sqeaking clutch - NCRS Discussion Boards
C-2 sqeaking clutch
  • Houston U.
    • June 30, 2000
    • 75
    C-2 sqeaking clutch
    I have a '62 with a recent clutch replacement. New pedal spring, fork w/rattle spring, and clutch package. Everytime I engage clutch, I hear a squeak from engine area. When I release pedal, I goes away. Any suggestions???? Thanks
  • Tracy C.
    • July 31, 2003
    • 2739
    Do the pivot balls on your "Z"bar need grease? *NM*
      Re: C-2 sqeaking clutch
      Does the squeaking occur when you depress the pedal, continue while the pedal is down, then stop when the pedal is up? If so, sounds like a throwout bearing problem. If it only "squeaks" momentarily while the pedal is moving, it's probably a linkage/Z-bar lubrication issue.
