HEI rotor misalignment issue - NCRS Discussion Boards
    • 15610
    Does anyone know of a HEI rotor that has a wider than OE tip.
    I'm trying to find an easy way of solving a misalignment issue.
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: HEI rotor misalignment issue
    duke i do it by changing the vacuum advance stops. go to www.kendrick-auto.com/ignition.htm for parts to do this if you do not want to make them yourself. the cap terminals in the HEI cap are wide but the problem i have found is that are too far from the rotor tip so i made a gauge to move the tips closer to the rotor as they are bendable. take a old distributor cap and cut a hole in the side so you can see the cap terminals,use your timing light to see where the rotor tips is when the distributor fires and move the vacuum advance stops to get it to fire where you want it to. MSD sells a rotor with a movable tip for phasing the rotor tip but i am not sure they have on for the HEI
