When I first apply the brakes on my '62, the pedal is a little low. However, after the first application, it comes up. That is, pumping the pedal makes the pedal come up. After the first application, the pedal is higher for subsequent applications. What's that usually indicative of?
When I rebuilt the system, I replaced everything except the master cylinder. I only threw a rebuild kit on that. Did not hone the bore. The system has DOT5 (silicone) fluid, but I'm sure it's properly bled.
