Reverse arm for C2 Hurst Shifter
  • Steve Daniel (37270)
    • February 1, 2002
    • 377
    I am looking for a proper C2 application Hurst shifter reverse arm (in the shifter, not on the transmission). It has a dogleg to clear the crossmember. I called Hurst and was told that they have them for their rebuild service, but don't sell them without the service. I have searched the net with no luck. Any suggestions?
    Steve
  • Pat #25912
    Re: Reverse arm for C2 Hurst Shifter
    Maybe buy an old used shifter for the part you are after. The older Hurst units with the non-removable handle can't be worth much.
    • Jerry Wagoner (36730)
      • September 1, 2001
      • 29
      I was able to order an arm from a local speed shop.You might check shops in your area.
        • February 1, 2002
        • 377
        Jerry
        Thanks. After I got a no from Hurst, I didn't think to check local shops.
        Steve
