c-3 Vacuum / Missing Parts Problems - NCRS Discussion Boards
  • Thomas J. Mattingly
    Dear Members;
    As you may or may not be able to tell, I am very new to Corvettes. I am also very limited mechanically (no big surprise). Please if anyone knows how I can find out which vacuum diagram is for my Vet. There are four vacuum hoses not connected. Two have bolts stuck in them, and two are just opened. My vacuum at idle is zero. This makes for very hard starting. There is a bracket on drivers side above vapor cannister, and the two open hoses are there, but nothing on the bracket. As you can tell this poor Vet is really in need of care. My hope was to use the VIN, to get info. Alas everywhere I check tells me the VIN is invalid. What am I doing wrong (pulling hair and screaming). Well enough bothering you folks, just needed to blow off a little. I will keep trying, and I pray someone can help me.
    Thanks for listening!!! Thomas J. Mattingly #38661
  • Dick W.
    • 10483
    Re: c-3 Vacuum / Missing Parts Problems
    Thomas, I would go to Dr. Rebuild for a vacuum schemetic. This would be a good starting point. The CORVETTE RESTORER magazine has had some very good articles over the years. It sounds lick your vacuum reservoir is missing. This is mounted on the LH inner fender. It would also help you to go look at another car close to your vintage.
    Good luck
    Dick
    Dick Whittington
    • Jim T.
      • March 1, 1993
      • 5351
      Thomas the 1979 servcie manual is available from www.helinc.com for your Corvette and should give you much valuable information about your Corvette. This service manual is the one that would be ordered from the information in your Corvettes owner manual. If you do not have a owners manual this should also be available from Helm as well.
