Previous C2 Hood Post (rebonding) - NCRS Discussion Boards
  • Peter M.
    • February 1, 1984
    • 361
    I know I read a recent post regararding original hood frame to hood skin flexible bond material - tot the outer edge resin sandwich but the cross bracing goop that never fully hardens. Can someone please advise what posting this was as I want to consider options for the correct rebond using factory correct material.
  • Chuck S.
    • April 1, 1992
    • 4668
    Re: Previous C2 Hood Post (rebonding)
    Peter, there is limited information regarding rebonding your hood in that post, but there are many other posts in the archives on bonding hoods and general fiberglass.
    Archive searches are really effective if you understand how the search engine works. Just type any word that is highly likely to be in a post or topic of interest. Use enough words/terms to narrow the field. If you use too many, then you are likely to get nothing. Then, click "ALL TERMS", and then click "Search".
    If ALL terms mentioned are in a post, then it is found. For example "hood bond" turns up a large number of posts, including the one you wanted, that may/may not be relevant; "hood brace bonding non-hardening material" results in zero hits.
