Hi folks -
I bought a nice '66 roadster a few months back. The knock off wheels (real K-O's attached to bolt-on adapters with spinners) are apparently reproductions. "Western Wheel", "15 X 6" and the max load are cast inside the wheel. Since my spare is a bolt on type (not a K-O), and the flats on the lug nuts that fasten the adapters show a lot of wear (probably from the repeated use of an air wrench), I'm wanting to replace the lug nuts in case I'm ever stuck by the side of the road with a flat. Note that I'm not interested in a K-O spare since I eventually plan to swap back to original style steel wheels and hubcaps.
Questions:
1. Is the lug nut for attaching the adapter different from the 'regular' lug nut that holds a steel wheel on? If so, what's the difference?
2. I've seen several people mention a safety pin that prevent the spinner from coming loose (and the disaterous results...). I don't see any such feature on my adapters, spinners, etc. Could someone please help me understand what / where this safety feature is?
Best Regards, Bob S.
Questions:
