some might remember that i developed the gradual onset of a low pitched metallic knocking sound. it sounds loudest when i use the stethoscope over the # 2 and 4 headers. it also seems to be timed to the cam system rather than engine rpm, although i cannot be sure.
i used the gm upper cylinder carbon remover and it had no effect. i disconneted the spark wires individually and it had no effect. the knocking is NOT there at idle but only comes on, audibally, at about 2000 rpm and higher. i do not think the knocking is there at lower engine speeds. could this be timing chain expanding with speed and hitting cover?? can a bad lifter act like this?? rod bearing?? i think my next step is to check the valve lash just to make sure. if that is ok, then i pull the intake manifold and look. sound reasonable??
werner
werner
