C2 Idle Issue - NCRS Discussion Boards
C2 Idle Issue
  • Rob M.
    • April 30, 2003
    • 657
    C2 Idle Issue
    Looking for some help.
    Last night, I started the car, a 66 327/300, (after a one week break) and noticed that the engine was idling about 300-400 RPMs faster than normal with choke. After the car warmed up and we had driven a little, the engine was still idling way to high @1100 RPMs when it usually is at 650. NO adjustments had been made at all to the engine from a week ago when the car idled normal. This just happened out of the blue. I let it sit over night and started it again this AM and have the same problem. Any thoughts?
    Rob
    Rob
    '66 327/300 Regional Top Flt
    '08 6 speed coupe
  • William V.
    • December 1, 1988
    • 399
    Re: C2 Idle Issue
    Check to see if the fast idle cam is sticking. It should drop down freely once the choke pull-off has vacuum and/or the engine warms up. A little carb cleaner may be needed to free the cam.
    (Engine off)With the choke wide open and a little throttle applied the cam should drop quickly when lifted and released.
    • Rob M.
      • April 30, 2003
      • 657
      Re: C2 Idle Issue
      Bill,
      Thanks for the tip, you're most likely right - I didn't check. I'll give it a try/look.
      Rob
      Rob
      '08 6 speed coupe
      • Verle R.
        • March 1, 1989
        • 1163
        Re: C2 Idle Issue
        Also check for a vacuum leak.
        Verle
