I thought I would share experience. Yesterday, I suddenly lost all power steering assist while backing into a parking space at a local show. Now, if you have ever driven a big block car that is supposed to have power steering and now doesn't, you quickly find out it is a job for a real man. Unfortunately, I guess I'm not anymore as it was a struggle to get into the parking space and subsequentially drive home. Now to what happened...
If you have power steering on a C3 (probably C2 and others?), you have undoubtably seen the power cylinder underneath the left front area of your car aft of the front wheel/tire. There are two hydraulic hoses attached that are coonected to the control valve at the other end. You can't miss this as it is usually leaking power steering fluid on your garage floor.
This hydraulic cylinder is waht provides power assist to your car. The inboard end is attached to the relay rod with a castle nut and cotter pin. The outboard end is attached to a bracket bolted to the frame with four bolts. This is the source of my problem. Apparently, the inboard attachment ears fractured a long time ago. This now transferred the load to the two remaing bolts on the outboard ears. Eventually, this worked loose and started to pull through the frame. With the bracket and power cylinder mis-aligned, the end of the power cylinder bent to approximately a 20 degree angle. The end of the cylinder finally snapped resulting in loss of power assist.
Symptoms of this prior to snapping, was a steering wheel shimmey in certain conditions. This is very similiar to the shimmey induced by a bad steering dampner. Don't let this happen to you. I'm looking at about $200 in parts. I'm also trying to find someone with mobile welding equipment to come to my house during the week of the Woodward Dream Cruise.
Take a good look at all four mounting ears on this bracket occasionally to ensure they are intact and tight.
