is my timing chain loose - NCRS Discussion Boards
  • Werner R.
    • March 3, 2008
    • 184
    i dropped the oil pan. when i reach up and push on the timing chain, i can push it in [towards the midline] about 1/2 to 3/4 of an inch. ought this to be repalced. any thoughts on anything else to do while i am at it??
    werner
  • William C.
    • May 31, 1975
    • 6037
    Re: is my timing chain loose
    At this point, you are at least halfway there, I would if I had that much play
    Bill Clupper #618
      Werner-----
      Absolutely replace it. Also, replace the crank and timing sprockets, too. My recommendation would be a Cloyes True Roller which are supplied as a matched set of sprockets and chain. About $90 for a small block.
