replacing starter on 76 - NCRS Discussion Boards
  • mike budra
    is this a tough job to do?
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: replacing starter on 76
    Mike Not a hard job only two bolts and a bracket in front. Make sure you mark the wires and don't mix them up as their are more than enough to get you in a fix if you mix them up. Disconnect the battery before you start!!!!!!! Lyle
    Lyle
    • mike budra
      well,got it off no problem.The dang thing looks pretty new too.It sounds to me like the solonoid isnt kicking in.You know,when you turn the key it just does that whinning sound....anyways,ill get another and give it a try.Does it usually pose a problem on these C3's that have headers on them?I mean with the heat and all.Thanks
      mike
