Joe Lucia- ignition cylinder number - NCRS Discussion Boards
  • Jon S.
    • November 1, 1992
    • 202
    Joe, what is the correct ignition switch and keys for my 62 250 hp 3 sp? I have a set of Briggs and Stratton keys with ignition cylinder model 602023 I could put in and it probably would work. But, is it correct for my car? Thanks in advance!
    Best regards, Jon
    Re: Joe Lucia- ignition cylinder number
    John-----
    I expect that if the ignition key is an octagon head, B&S key that it will be correct. I don't have a B&S cross reference for the lock cylinder assembly. However, the GM part number for the correct, UNCODED lock cylinder assembly is 3772085. That's about all I can tell you.
    • Jon S.
      • November 1, 1992
      • 202
      Thanks Joe! *NM*
