Steering wheel 180 degrees off - NCRS Discussion Boards
  • Harmon C.
    • August 31, 1994
    • 3228
    This was posted a week or so ago. The way it can happen is if you restore your rag joint or just remove both bolts by taking off the keepers you can put them in the wrong holes and your wheel will be 180 degrees off. The thread size is so they will assemble only one way but the shank on both are the same so when removed you can reinstall them 180 off in the joint. Lyle
    Lyle
