C1 Splash shield seals - NCRS Discussion Boards
  • Chris H.
    • April 30, 1990
    • 817
    I have a set of splash shield seals. The instructions say to cut as needed.
    The AIM does not show how to install (must have come into the plant with the shield) and the illustration is not clear.
    I assume that I need to use 3M weatherstrip to hold on.
    Is the seal supposed to bend over the 1/2" at the top to the end of the metal. Seems real hard to get the bend in the rubber and keep it there.
    How far down should the seal go on the shield?
    Thanks, Chris
  • Dennis A.
    • April 30, 1999
    • 1010
    Re: C1 Splash shield seals
    Chris...
    The seals are mounted along the side of the shield that faces or mounts against the car body. No cutting should be required. 3m adhesive applied before installing the shields works well. Don't forget the undercoat (rubberize)
