'57 - '60 radiator upper hose #3728490 - NCRS Discussion Boards
  • G B.
    • December 1, 1974
    • 1407
    I don't like the poor fitting version of this hose that is sold by many suppliers today. It may match the original GM drawings, but the angle of the last bend on the engine end is not right. As a result, this hose stays slightly distorted just above the thermostat housing neck.
    A local CarQuest let me go through their stock of a couple of hundred radiator hoses. I found one hose design, #21998, that actually does fit this application ('57 - '60 w/FI or 2x4's) properly. I had to cut 1" off the engine end and about 8" off the radiator end, but then it fit like a glove. CarQuest sells this hose for about $14.
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    Jerry, Thanks for the info...
    ... I always thought the fit of the "repro" sucked (sorry)... but the angle is just all wrong. Hard to believe the General would have done it this way. At least it's nice to know there is a reasonable alternative out there that fits.
    • Loren L.
      • April 30, 1976
      • 4104
      Probably explains why the service replacements
      have a different angle - okay, we'll fix it now, after all you FUSSBUDGETS
      complained to your service manager and generated all that mail.......
