If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
I checked the factory manuel for the tolerances of the front wheel bearings on my
66 -- the range of .001 - .005 when while grasping tire at top and bottom and moving the tire in and out seems "very tight". Is this the way you check your bearings?
Bill
Twenty threads per inch and six flats with two (perpendicular) cotter pin holes means each one-twelveth turn reduces clearance by .004", so there is ONE setting that will achieve the correct clearance.
Keep moving the nut forward in one-twelveth turn increments and install the cotter pin, until you cannot feel any clearance, then back off one-twelveth and check for clearance. If a tiny amount is evident, spread the cotter pin, and install the hub cap.
With new bearings the nut should be slightly torqued - I think the spec is 12 or 20 foot pounds, and spin the wheel a few times. This should "seat" the bearings.
Then back off the nut and tighten it with your fingers as much as possible, and whatever extra is required with a crescent wrench to install the cotter in the next available location. Then check for clearance. If none, back off the nut one-twelveth, and check clearance.
As mentioned the way to check clearance is to grab the top and bottom of the tire and "wiggle" it. You should be able to hear/feel very slight play.
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
