C2-67 CoupeTank Sticker - NCRS Discussion Boards
  • Mike Swanson
    Should I be able to see a tank sticker, if present, by pulling back the overflow boot and looking thru the opening?
    Mike Swanson
  • Jim W.
    • February 1, 1980
    • 324
    Re: C2-67 CoupeTank Sticker
    Mike, It's possible. If not, you should be able to feel it with the tips of your fingers to the left and below the opening. Good luck. Jim Weeks, Member #2978
    • Wayne W.
      • April 30, 1982
      • 3605
      You can see it, but cant read it.
      • Mike Swanson
        Thanks guys! I'm pretty sure I am getting a good look at the tank from above. It looks relatively clean so I should be able to see something but no luck. Maybe some already got to it. Dammit! While I wasn't really looking forward to dropping the tank if I did see something, it would have been real exciting!
        Thanks again,
        Mike
        • Jon #40768
          Re: C2-67 You will never know until you drop it.
          I could not see mine until I dropped the tank. I even damaged the rubber seal before dropping the tank. It was a great experiance. My car had all of the indications of a 435 horse high option car, but I could not confirm it as original until I dropped the tank. Since I had been out of the hobby for about 17 years, I did not know a sticker was ever used. When I found out about stickers, I came home and dropped the tank that night. The sticker was heavily damaged, but the 435horse and leather were legible. If you are slightly interested, drop the tank.
          Jon
