My 65 L79 has been reading high oil pressure since I acquired it. The motor was rebuilt before I owned it, and the rebuilder installed a high volume oil pump. I just replaced the oil pump with a standard unit and the reading is lower, but still over 60 lbs. at idle. The archives suggest using a test gauge to verify the reading. I checked the Internet and the only one I found cost $125. Is there a cheaper method for checking oil pressure? If the gauge is found to be faulty, how can it be recalibrated? Is there anything else I should look for that would cause the high reading? Any advice would be greatly appreciated.
Thanks!
Thanks!
