COOLING SYSTEM CAPACITY - NCRS Discussion Boards
  • Fred Hammerle
    Can someone pls advise the cooling capacity spec, in quarts, for a '64 327/365. Thanks!
  • Joe C.
    • August 31, 1999
    • 4598
    Re: COOLING SYSTEM CAPACITY
    Fred:
    Your engine, WITH heater has a total cap of 15 quarts, as follows:
    1. 3 quarts EACH side of the block. This can only be drained by removing BOTH drain plugs.
    2. 9 quarts for the balance, including rad, upper part of engine, etc, etc.
    I don't know about "heater delete" , but the erronious shop manual, and the erroneous owners manual both list a 1 qt deficit here.
    How do I know? Empirically.
    Joe
    • Fred Hammerle
      Thanks Joe. My heater is blocked off, so will assume a capcity of 14 quarts with BOTH sides of the block drained. Fred
