Early 70 A/C Suction Line - NCRS Discussion Boards
  • Jeffrey S.
    Infrequent User
    • February 1, 1994
    • 5
    I need information on suction line configuration on a 02-02-70 build date; 350/300hp. I know there are two different style compressor, muffler and tube assemblies for the small block.
    The first one is 3963760 (up to 05/18/70); the second one is 3992144.
    Part #3963760 uses a separate line running from the compressor to the POA valve. Is the original configuration for this line rigid aluminum or rubber hose?
    Any information would be greatly appreciated.
    Thanks....Jeff
  • Geoff C.
    • May 31, 1979
    • 1613
    AC lines
    Completely rigid formed aluminum lines (without any rubber freon hose) did not appear until 74 on the condenser outlet line. That line was in 2 pieces to lead back to the VIR. All prior models use freon hose clamped or crimped to aluminum fittings for the various connections.
