My 1960 283/270 used to run hot, > 200 degrees acc'd to the temp gauge. Upon troubleshooting, I decided that the problem was the leaky radiator. After replacing it with a correct DeWitt's toptank model, the car now runs cold, acc'd to the temp gauge! Of course I was happy the car wasn't running hot anymore, but now the gauge barely gets to the first mark to the right of the 100 degree mark (I'm guessing that mark is about 120 degrees). I installed a new fail-safe 180 degree thermostat when doing the radiator job, and I know the engine is getting to that temp because the top hose is hot. The last time I ran the car before changing out the old radiator I let it idle a while in the garage, until the temp gauge almost reached 220. After shutting the car off, I could hear the coolant in the radiator starting to boil so I was pretty sure the temp reading was accurate. I can't verify the originality of the temp sender, but I recall from previous experience that the incorrect calibration senders would peg out the temp gauge. Radiator cap is the original 13# type. I don't know if the temp sender is bad, or the gauge is bad. Any ideas?
Mike Tess
Mike Tess
