'66 BB ENGINE TUNING...OR NOT - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    I started up my '66 big block after installing a new cam, lifters, pushrods and rocker arms. Before starting it I set the timing mark ar "0" and installed the distributor as per the manual. I've broken in the cam and the engine runs well, has a good idle and acceleration and operates at a normal temperature. Anything wrong with just leaving everything as is, rather than acrually setting the timing with a light, adjusting idle mixtures, etc. I'm inclined to use the "leave well enough alone" theory at this point.
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: '66 BB ENGINE TUNING...OR NOT
    you should check the timing with a light to be sure and recheck the valve lash because new parts "wear in" and change the lash
