what color grey for 67 shocks?? - NCRS Discussion Boards
  • Michael F.
    • 745
    what color/shade of grey were the original shocks on a 67 midyear, any local type brands of paint I can buy, krylon, duplicolor etc. this is not for a top flight judged car but want to look correct for ME. thanks.
    Michael
    70 Mulsanne Blue LT-1
    03 Electron Blue Z06
  • Chuck S.
    • April 1, 1992
    • 4668
    Re: what color grey for 67 shocks??
    Michael, you will need to find a dark semi-gloss gray, like a battleship gray. I bought a half-pint for a water meter once...that color would be incorrect, but OK for a driver if available in a spray can.
    The shock color was actually a bluish gray, but you aren't going find that color at Home Depot. Personally, if it were me, I would just order a can (or two) of shock paint from Quanta Products...it's a little on the glossy side if two wet coats are applied. Maybe a can will cost you $20 instead of $5, but anything worth doing is worth doing right.
    • Scott Marzahl
      Did you do a search of the archives, I used an available spray paint from a local hardware store based on responses a year or so ago. I'm traveling right now but I can tell you the brand and color when I get home.
      • Mike Cobine
        With all the new car grays out there today
        you might find something close enough in a can now. It seems like there are a couple dozen shades of gray for the SUVs now.
        • Michael F.
          • 745
          thanks Scott I would appreciate that.
          Michael
