67 Corvette block question? - NCRS Discussion Boards
  • Don Luczak
    I have a 67 427 (351 block). My question is. Was this the 435 hp version with the tri-power setup? Was this considered a L-71 or L-72 code? And my last question is, if not equipped with the tri-power setup what manifold P/N could also be on this engine? Any help is greatly appreciated!
  • William C.
    • May 31, 1975
    • 6037
    Re: 67 Corvette block question?
    The 351 block was used on severaal engines, what is the code on the pass side front corner of the block? That is where the engine is identified as to a particular hp configuration at the time of engine build.
    Bill Clupper #618
