56 VETTE DISK BRAKES - NCRS Discussion Boards
  • mike williamsMM
    I HAVE A 56 VETTE.IS THERE A WAY TO CHANGE TO DISK BRAKES WITHOUT DRILLING NEW HOLES IN THE FRAMS? Also IS THERE A STEERING BOX THAT CAN BE USED AND CAN I still use the 56 steering wheel?
  • Dale Pearman
    Re: 56 VETTE DISK BRAKES
    Why do you want to alter your Corvette with a braking systems that offers no advantages and uses inferior Ford Pinto roller bearings? (assuming you'll pop for the kit) Do you believe the aftermarket engineering/supplier to be more competent that a whole roomful of GM Engineers? Been there-done that! Waste of time & money!
    Dale.
