rev limiter? - NCRS Discussion Boards
rev limiter?
  • Frank H.
    • May 22, 2013
    • 148
    rev limiter?
    Any suggestion on a simple rev limiter.
    Frank
  • Dale C.
    Infrequent User
    • March 1, 1987
    • 26
    Re: rev limiter?
    Jeggs is where I got mine for my 67 435. It's electronic and has different little mods that you can plug in for the various rev's that your looking for. I installed mine for drag racing so I wouldn't over rev the engine. First time I went down the track I thought I was running out of gas, then realized that the rev limiter was kicking in. Good luck Dale
      Re: rev limiter?
      Crane has a drop-in electronic module to replace the points which has a built-in adjustable rev limiter.
      • Frank H.
        • May 22, 2013
        • 148
        Re: rev limiter?
        I,ve seen the crane one is nice and afordable,and plan to get one for my spare dist.
        I think Dales talking about a MSD ignition,I've used a MSD 6AL before with the chips to stagger misfires,and just met a guy that stuffed one on those boards in his TI amplifier case by splitting the board and hard wiring the the leads.
        and uses his TI dist. with it.
        I'll have to check archives I remember one mentioned.
        I don't want to replace anything,I have the stock set-ups on both 67 TI and 62 with a single point vacuum dist. plus a vintage Judsen CeeDee box my grandfather
        gave me ten years ago.
        Just something to use say for a one time drag race day.
