C1 Generator Tag Rivet Removel - NCRS Discussion Boards
  • Mike Harpster
    The generator on my '62 has no tag and the rivets are broken off in the generator (broken off flush with the outer surface). I just had the generator rebuilt and the shop unsuccessfully tried to remove the remaining parts of the rivets with a punch and a hammer. From reading the archives I learned that these are blind holes.
    Any tips on how to remove the ends of the rivets now that they have been pounded into the hole?
    Mike
    #40893
  • Wayne P.
    • August 31, 1975
    • 1025
    Small drill bit ! *NM*
    • Christopher R.
      • March 31, 1975
      • 1599
      Re: C1 Generator Tag Rivet Removel
      That's what happened to mine too. I just drilled them out. The rivet is softer than the case. So using a small drill bit in there pretty much cleaned out the old hole.
      Do be careful. Use a drill stop on the bit. You'll ruin the generator if the drill goes through the case. I didn't trust the new rivets to hold my expensive tag on. I secured the tag to the case with epoxy. The new rivets are now the "suspenders" in this belt and suspender attachment.
      Remember that the tag goes on "upside down."
      • Mike Harpster
        Thanks... *NM*
        • Dave Suesz
          Prior to rebuild, I
          Used a very sharp wood chisel pushed under the tag an gently pried up to remove. Flawless results, I was even able to re-use the original rivets.
