Thanks to the advice of Duke and a number of other NCRS members I am happy to report that the 67 427/435 is now running stronger than ever, on 94 octane pump gas...without detonation or overheating at idle. The distributor was curved to factory spec...a Napa/Echlin VC 1765 Vacuum advance can was installed...and connected directly to the FULL manifold vacuum source below the center carb (not the original "ported" source).....the timing was set at 8 degrees initial...10 degrees at 3600 RPM and 38 degrees total.
I happened to stop by Dave Feidler's booth at Carlisle and he was nice enough to discuss some of my distributor issues with me. In particular, and perhaps of real interest to those who read and post on this board, he said that many of the reproduction vacuum cans he has tested did NOT provide the indicated/required vacuum. He has gone back to recalibrating his own for certainty. We tested my 201 reproduction can(bought from Long Island)and it was way off. The VC1810 and the first VC1765 cans I bought from NAPA were also off. The second VC1765 can was very close to spec and that is what we installed. Dave also said that he had seen some discussion on the NCRS Discussion Board that seemed to say that the 360 can was correct for the 427/435 distributor....and he did not understand why anyone would think that. He said he has seen many original 427/435 distributors with the 201 can and he is sure that is the correct can for that application. Well, I hope others can benefit from what I have learned...and thanks to all who provide advice and guidance with respect to our Corvette issues.
