'67 REAR BRAKE CALIPER BLEEDING - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    I decided to re-bleed the rear calipers to make sure no air remained in the system. The pedal was just a little softer than I though it should be. I tried gravity bleeding the calipers but no fluid wanted to come out.(The front calipers gravity bleed fine) I then tried a hand vacuum bleeding kit with slightly better success. At this point, no fluid comes out when the brake pedal is depressed. The master cylinder is full and no changes have been to the lines or any of them dissconnected.
  • Mike McKown
    Re: '67 REAR BRAKE CALIPER BLEEDING
    Sounds like the piston shifted in your distribution block and sht the fluid of to the rear brakes.
