I let the rear half of my master cylinder run dry while vacuum bleeding the rear calipers. I refilled it, but can't get any fluid out of the rear bleeder valves depressing the brake pedal now. Assuming this is from letting it run dry, can I resolve this without disconnecting any lines from the master cylinder?
'67 MASTER BRAKE CYLINDER BLEEDING
Re: '67 MASTER BRAKE CYLINDER BLEEDING
Rob,
Patience is the key here to get a firm pedal. Fill the MC, open the valve on the right rear and go and have breakfast. I slip on a clear plastic line and put the end in a cup or can. Check on the MC and keep it full this time. Do the same for the left rear. It won't take as long so keep an eye on the left rear. Don't eat too many wheaties.
JR- Top
Suggests you've got a LOT of air in the rear lines to bleed out. You might want to consider buying/using a Mityvac hand pump ($30 list, autoparts stores + Eastwood catalog) to make the bleeding a 1-man job by 'sucking' fluid through the lines from the rear wheels vs. pushing it through via the brake pedal....- Top
Vette Brakes has them as do other vendors. Search for "Speed Bleeders"
Here is an example:
http://www.vbandp.com/SearchResult.a...eed%20bleeders
Dave ZubererDave Zuberer- Top
- Top
Rob If the master cylinder hase been sleeved I have been told the system won't gravity bleed. I can not make a resleeved M/C's gravity bleed and have had the same results you are having. LyleLyle
- Top
Lyle - I am having a hard time understanding why sleeving would have any bearing on bleeding, if the holes are all drilled correctly after sleeving, there shouls be no difference at all in the process....Craig- Top
Rob - yes, air would have entered the rear section of the MC again, as far as your question about bleeding just the rear section, I am not sure but I believe that the piston travel may move air from the rear section to the front section when it is stroked. It would be best to rebleed again assuming both sections have trapped air....Craig- Top
Lyle - they may not drip with the cover installed, if the cover is off it should certainly gravity bleed. My cylinder from Apple hydraulics has every port carefully drilled through just as the original did. I haven't proven or disproven your theory yet though as I have not installed it or rebuild the piston and seals yet, but every orifice appears as original...Craig- Top
Do I need to detach the both brake brake lines in order to bleed the master cylinder? The first time I did it was on a bench with fittings where the lines attach. Craig, the way it is now, I can't even get enough fluid to the rear lines to push the pads against the rotors, even pumping the pedal several times.- Top
