C3 steering wheel shims - NCRS Discussion Boards
  • Dale P.
    • September 30, 1995
    • 248
    I am installing my steering wheel back into my 68 .. the car has telescoping steering .. part number 3910765 is a shim that goes under the horn contact asm. and above the tel locking knob ... when I took mine apart there were no shims.
    questions .. 1) can I use plate washers as a shim under each of the three screws 2) how do I know how many shims is enough .. I don't see any reference to a gap ....... Could this explain why the horn would blow if I loosened the tele to adjust and then stop after I tightened it back up?
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: C3 steering wheel shims
    Dale I can't recall seeing no shims one to three is the norm. I would buy some shims and experiment till the horn works as it should. Lyle
    Lyle
