As I understand it, the 67 should have an obround cross-section front bow as opposed to the earlier smaller round bow. Is the top frame otherwise the same and, if so, can the correct bow be found anywhere and replaced as an individual component? At some point in my car's sordid past someone has apparently installed an earlier model frame if I've got my facts straight. ????
Also, the car sat in a barn (w/ hardtop) for >10 yrs before I got it. When I tried to put the soft top up, I could not easily (read not anywhere near easily) latch both ends of the top. I did "force" it one time but it clearly isn't right. I am writing this off to the top taking a "set" from sitting folded so long. It really just seems to have shrunk... Is that far fetched or does it pass the common sense test? (BTW, 60F & the door gaps & windows, etc all fit fine. And the hardtop is fine. The soft top fabric is a replacement from the 70's by the looks of things.)
Thank you all for helping me learn so much on this board!!! -Karl
